water pump
toopay
I have changed the impeller on my motor but is still not pumping water through taller tail, is there something else that I should change since it is not pumping.
40hp mercury classic or old 50.
turtles11756
Re: water pump
the key on the impeller is in place ? .put the impeller housing on and turn driveshaft clockwise as you apply pressure to install over impeller on greased impeller blades. check the the telltale hole is not clogged
huntin dawg
Re: water pump
Did you reconnect thr water tube when you put the LU back on? May sound silly but sometimes they pop off and you don't know it.
HD
