using 25 micron separator with a 2004 90 hp Yamaha 2 stroke. I had some fuel problems (WATER IN FUEL) . CAN I SWITCH TO A 10 MICRON OR WOULD THERE BE A PROBLEM WITH FUEL RESTRICTION. SOME MANAFACTURERS SAY NOT TO USE 10 MICRON BECAUSE OF THE POSSIBILTY OF RESTRICTING FUEL TO THE FUEL PUMP. ADVICE ON THIS WOULD BE APPRECIATED. CARBS WERE MESSED UP BECAUSE OF THE FUEL PROBLEM, THOUGHT THE 10 MICRON MIGHT HELP TO REDUCE THAT
