Water Seperator Filter
1stoutboard
I own a 2004 yamaha 90HP, 2 stroke. I was surprised that yamaha did not install the filter as a standard part. Should I have it installed? Is it something very involved to do?
Solittle
Re: Water Seperator Filter
They are a must in my book. They will keep water and crud out of your motor.
fishonpeter
I already have the filter, I was asking if someone else had a Seaswirl Striper with a filter installed so I could see the location. And then decide if I wanted mine to be located in the same area. I was thinking of mounting my filter inside the transom to keep the water off. And the flying sinker's and other stuff that happens back there.
Cricket Too
I have mine mounted on the port inside of the transom and have never had any problems with it getting in the way or things hiting it.
fishonpeter
Originally posted by mmcpeck:<br />I have mine mounted on the port inside of the transom and have never had any problems with it getting in the way or things hiting it.
fishonpeter
Could you send me a digital picture?
