Water seperator
jjhjrcmh
I have read that the water seperator should be before the check valve and also after the check valve. Which is correct? Also should filter be installed below height of fuel pump but above the fuel tank height? thanks for all the help. The engine is a E200TXECM
Daviet
Re: Water seperator
I have had the seperator mounted both before and after the check valve, didn't seem to make any difference.
Are you running a built in tank? If so you don't have much choice on the height of the seperator.
I mount them below the fuel pump but above the tank, but on built in tanks it's the only way you can do it.
jjhjrcmh
Re: Water seperator
thank you so its a prefference thing plus ease of replacing.
Chris1956
Re: Water seperator
Mount the water separator between the primer bulb and the fuel tank. That is the proper place.
