Cpt Landlocked
Thread starter- Joined
- Jul 30, 2007
- 3
I have a 1978 Sea Ray 220 Overnighter with a 2002 260 Hp Mercruiser (GM 350). Unfortunately the previous owner has no idea what maintenance was and even though the motor had very low hours on it, it needed a lot of work. After tuning it up I took it out for its second shakedown run and it overheated when at full throttle. I decided to clean out the exhaust risers, replace the impeller, and all the bellows. I found out it also had a blown head gasket on one side of the motor so I also replaced that. It is nearly ready to go in the water and while removing the right side exhaust riser and rubber connectors the worn exhaust shutter fell down into the y pipe. Does anyone have any suggestions on how to remove it without removing the engine?
