anauburnfan
Thread starter- Joined
- Aug 23, 2010
- 24
I recently purchased a 1988 Johnson 200. It runs fine on hose at any speed or on water once in gear above idle. It is difficult to crank in water and idles rough with regular miss and stall at idle -- usually when trying to dock... Anything above idle it runs great. I noticed that there is water coming out from between the bottom of the crankcase and the exhaust housing at midsection. On the hose, this is more like a leak, when in water, it is squirting out. It is on the starboard side just above the fitting for the tubing that eventually reaches the telltail. Is this a major concern, and could it be related to my idle problem? There is also a lot of fuel oil that leaks down the outside of the midsection. I cannot locate the source of this leak, but it appears to be coming from the fore side of the intake manifold though the carbs do not seem to be leaking. When I mentioned this to the boat shop that sold the motor, he indicated that it is probably just the carb bowls leaking and that I should store the motor upright (not tilted). I told him about the rough idle problem and he said it was probably due to gunk in the carbs because the boat sat for ten years between old motor and this one. He said I should bring the motor I bought from him in to have the carbs cleaned again. It has 2 spin on fuel filters in series, so I dont see how tank crud (which I have no doubt exists) could be making it to the carbs. Am I incorrect in thinking this? The second spin on has a clear bowl with water separator and no tank crud shows up there, though the first filter definitely has crud and I have changed twice in addition to adding a clear in line pre filter. Thanks for any advice on this long post.
