Water/Steam from exhaust manifold
PDubs
Engine is 502 MAG, bone stock, 500 hours. Have had the boat for three seasons now and this is the first time this has happened and only on the starboard side. On cold start, there is some colorless/odorless vapor or steam coming from what appears to be the underside of the exhaust manifold. Rubbing the same area, I get a colorless/odorless liquid on my fingers. Seems like water as it is not slippery like an oil or similar. After running the engine for a bit (30-60mins) and starting again I do not see this vapor.
Any/all help is greatly appreciated. I'm assuming it's the exhaust manifold but welcome other opinions on what to check for and/or replace. Video attached below.
tpenfield
Re: Water/Steam from exhaust manifold
Probably water . . . you should check that manifold (and maybe the other one) for cracks or perforations. The best thing would be to take it off and do and inspection and leak test.
PDubs
Thanks. Needed a second opinion before I start removing things.
