Water stopped flowing out the tell-tale
gss036
Re: Water stopped flowing out the tell-tale
http://www.timesert.com/ <br />Here is another style which claims they are better, but you know how that goes.<br />Did you have any problems (dropping)removing the lower cowling?
gss036
Since your motor is different than mine, may not be an issue. There are 4 small screws/bolts that hold the two pieces together and allows you to seperate the pieces and drop it down or remove if needed. This allows better access to work on the poppit assy. Just a suggestion, thinking out loud.
