My boat had a recent problem which turned out to be water in the right hand cylinder bank. I discovered the water had got into the engine from the exhaust manifold. Further investigation showed that I only have a water stopper valve in the exhaust feeding the left cylinders.. Should there also be a water stopper valve in the right hand exhaust? The Mercruiser manual only seems to show one stopper valve which just seems very odd to me? I would expect two valves (one in each exhaust) or none? I find it a strange coincedence that the side with no water stopper valve was the same side that had water in all the cylinders. I am hoping that fitting a stopper valve in the right side will prevent any further re-occurance of this..
Can anyone confirm if there should be one or two water stopper valves? Its a mercruiser Alpha II drive with a V6 4.3L engine, 1991 model
Thanks Gary
Thanks Gary
