Re: Water stuck in bilge - Boat too low on trailer? Please help, PIC INSIDE.
UPLOADED PROSPECTIVE PICTURE:
Thanks again to all who replied. OK, so if I understand you all correctly, is this the way it should look like? If so then I must say it looks a bit odd. I'm just worried that if I do flip it this way then when I launch in and out, it might scrape the rubber rollers potentially causing damage due to the angle of the winch's steel cable.
Also, my winch is rated for 2000lbs and barely has enough power to get the hull to touch the hull let alone lifting it. I also tried to loop it around to give it more power but it didn't work.
