- Joined
- Jul 18, 2011
- 18,866
As I gain experience with my 'new-to-me' boat, I seem to continually come up with ideas on how to make things a bit better.
This weekend was the water system . . . it has a fairly large water tank in the bow and a pressure pump. There is a deck fitting up by the anchor locker. However, as I filled the tank, there was not good way to tell how much water was in there and when it was full. I ended up guessing and occasionally going up and down from the deck to the v-berth to visually check the tank to see if it looked full.
I also wanted to be able to wash the deck off when I was away from the main dock, but the plumbing seemed to route aft from the pressure pump heading towards the head and the wet bar. I figured that if I could tap into the plumbing at the bow, I could install a faucet and hose in the anchor locker and take it out when needed, etc.
So, my plan for the weekend was to install a tank gauge and sender for the water tank and a faucet and hose. Both of these things would be in the anchor locker for easy access.
Here are a few photos from the weekend . . .
Tapping into the plumbing and installing the sender in the tank. I used a regular fuel gauge and sender . . . but I suppose I should re-label the gauge to say "water" at some point. I also got some PEX tubing and fittings at Lowes. That stuff is wicked easy to work with . . .
Then I drilled a couple of holes in the bulkhead/anchor locker for the gauge and the faucet plumbing . . .
I hooked up all the wiring and tapped into the 12Volt outlet circuit. I have a 5 amp CB that I should install at some point, but that part may be next weekend's addendum.
Then I tested the plumbing under pressure and activated the gauge . . . The water tank is about 1/2 full . . . or pehaps it is half empty, not quite sure. . . . Now when I need to check the water level, I can just open the anchor locker, and the deck fill fitting is right next to the locker, so I can see the gauge as I fill the tank.
Here is a view of the faucet and hose. . . . Seems to work OK.
At that point, the Admiral and First Mate were wanting to go out for a cruise around the bay . . . so I put the v-berth back together . . .
Since the hose and the anchor may not get along that well over time, my plan is to make a bow pulpit and keep the anchor on deck. . . then just the rode will be in the locker.
That will next weekend's project . . .
