boatissues
Thread starter- Joined
- Aug 28, 2017
- 2
97 7.4l mercruiser. (no idea what serial number is) Bravo1 outrdrive
Temp gauge was working fine, pulled the oil cooler and removed about 1 1/2 impeller blades worth of crap and reinstalled it. Ever since temp gauge will not register unless I shut it down and sit for about 5 minutes. Turn the key on and it goes to about 175. Start the engine and it dives to 40 in about 5 seconds and stays there.
New impeller, new OEM thermostat and gaskets, tried new sensor no difference. Have grounded the gauge and it pegs. It did finally go to about 105 the other day when I had made an extended run at 4K rpm (usually cruise at about 3k) Hit 105 and then dropped to 40, repeated until we stopped. Scratching my head over this one...
