captlee
Thread starter- Joined
- Aug 22, 2008
- 101
Rencently purchased a 1986 proline with a 1996 90hp Evinrude ocean pro on it. No guages on the instument panel work (I got the trim guage working today). Theres 1 aftermarket sending unit on the port side going back to a temp guage that doesnt appear to work. I checked the alarm/horn after reading another post, it was disconnected (the purple wire coming from the ignition was pulled loose from the connector on the alarm). When I put power to it made a very low static noise but no loud noise, grounding the tan wire made no differnce.
Its obvious the alarm needs to be replaced, but is there a way to test the factory sending units/ sensors in the heads? Can those be used with a guage or are they just for an alarm? If I were to go with a guage shouldnt it have 2 sending units, 1 in each head like the originals? Would this require 2 guages or just both sensors go to 1 temp. guage?
Im trying to decide if I should keep the alarm or go with an actual temp. guage. Ive also seen water pressure guages would that be a better choice?
Also... any help/advice with testing the tach and making sure its hooked up correctly would be appreciated. Thanks in advance.
Lee
Lee
