Water Tube and Grommet
xdgt03
I have an overheating problem and believe I've traced it to the water tube/grommet in the lower housing of the outdrive. I have a new impeller. It pumps from the water pump on the motor, there is no thermostat, and it flows fine with the muffs on. When I put the outdrive in water it does not suck water in.
The impeller is installed correctly.
I don't think the brass tube would go bad but the seal/grommet surely could. Are these available somewhere. I checked a bit but I don't know what part number is the correct one.
Any help would be greatly appreciated.
