2006 Mercury 25 H.P. engine F25ELPT S/N OR125093. How do you replace the water tube from the water pump to engine block. It looks like it has a piece missing and no water gets to pee hole. Changed impeller in water pump. Does the driveshaft housing have to come off? Will that drain all the oil from the engine? How many new gaskets are required here? Tried pulling it down to no avail.
