Sheetmetal
- Joined
- Oct 9, 2010
- 32
I'm having troubles with the flow of water thru the engine at low rpm. The water pump appears to be clean and in good shape. water pees out at high rpm but not low. the water appears to be leaking from the water tube as it goes up the leg and I can't seem to pull the tube out from the bottom. Whats holding it in? I thought it was just pushed into a gromet.
