readyakira
Thread starter- Joined
- Apr 6, 2005
- 22
Re: waterpump?
all together it took me 3hrs. But I ran into unexpected complications. If everything is as should be this job should be easy to do in under an hour. I hadn't been told but figured out is was easiest to install the impeller in the pump housing and slide the both down onto the shaft. It was very easy to see which way the blades needed to be. As a matter of fact after everything was done and I was cleaning up for the night the old impeller was still curved in the direction of travel a bit. I did the whole pump kit to be safe. You can get by with just the impeller if the plates are not scratched I suppose. But I didnt want to take any chances. Tommorrow is compression tests and carb cleaning... maybe by the weekend (mine starts on monday) the boat will be ready for water.
