Ways iboaters might fix their cars
RogersJetboat454
Re: Ways iboaters might fix their cars
About 5 years ago I purchased my buddy's BIL's '95 S-10 Blazer for the price the dealership was gunna give him as a trade in ($600). It had about 3 inches worth of teeth missing off the flex plate due to a failing starter that he had already replaced. When I went to pick it up at his house, I figured it would be no biggie to get it running, I would just put a big 1/2 ratchet on the crank pulley, and turn it past the bad spot on the flex plate to start it so I could get it home.
Well... things didn't work out that way. No matter what I did, all the new starter would do is spin and not engage. Luckily I had brought a Jack and stands with me and hand tools. I pulled down the new starter and took a look. It was a nice piece of crap Autozone special, and all but a couple of teeth on the Bendix drive were now broken off due to the ganked flex plate.
He still had the original starter in the back that he was going to return for the core, so I got the bright idea of making 1 good starter out of the two. Mind you, this is all happening at 9PM at night, on the ground in the driveway of his apartment building. For what ever reason (can't remember), I ended up having to braid two of the stranded wires from the solenoid to the brush packs together, then wrap it with electrical tape to hold it. In the end when the finished product was placed back in the truck, and the flex plate was placed in a good position, she fired right up and got me home.
That Blazer is now my mothers that shes been driving every day to work for the past 4 years. :)
BlkY2k
Hey if one is good, 2 must be.....
Bob_VT
Graffenwohr???:eek: I don't know which was worse. Graffenwohr or Hohenfels.
I bet if I rummage through my stuff in the attic I could find something with a trace of that mud!!!! I have about a total of one year being deployed there if I add up all the times..........img015.psd.jpg I am the one in the green T .......had to have a case of beer to fix the flats.
BlkY2k
Compound boost Phil. I kinda like the looks of this one. The guys that put it together got it to run but not much testing. Somebody broke in and stole it.
RogersJetboat454
Is that what I think it is? A blown 3.8/4.2L Ford?
BlkY2k
Yeh it sure is Roger. There are a couple companys out there that build adaptors to put the m112 blower on the 3.8/4.2. The 4.2 is a stout little motor when blown. I know of a few that have pushed the 500hp range although its alot easier to go turbo and get even more.
RogersJetboat454
Despite the 3.8/4.2L bad rap for blown head gaskets, I have always had respect for them. Quite happy with the 4.2L in my F-150. Some people say that Ford ripped off the Buick 3.8/3800 when they designed their own 3.8. I don't know about that...
BlkY2k
I had to give up at pg 8. They walk amongst us, I`m telling ya.
dockwrecker
Back in the late 70?s, me and a teammate were coming home from a ski race at Steamboat Springs in his 68? Ford Cortina. (British shttbox) We were just leaving Steamboat in blizzard conditions when the clutch slave started leaking fluid like mad. We pulled into a local convenience store in search of brake fluid. After determining that the fluid ran out of the slave pretty much as fast as we put it in the master, we could see that we were going to need a ton of fluid to limp home. We were fairly strapped for cash to boot and the thought of spending $50 on brake fluid was unacceptable. We too needed fluid ourselves, and elected to purchase a dual purpose fluid that we could get in quantity that would satisfy both needs. Two cases of Coors seemed the perfect solution if kidney filtered first to get rid of any air bubbles. We began processing our new clutch fluid in the parking lot immediately. After we had filtered about 48 oz of fluid back into its original containers and topping off the master cylinder, we hit the road. We could go about 10 miles before needing to top off the master so processing fluid at a high rate was imperative. All was going swimmingly until a pothole upset several cans of our processed fluid all over the floorboards. We would not be deterred however and worked earnestly to replenish the spilled containers.
We drove 300 miles home that way and frankly didn?t really care much about the inconvenience of stopping so many times. I also declined to ever ride in the Cortina again, at least not with the windows up.
