harringtondav
Thread starter- Joined
- May 26, 2018
- 2,523
I'm prepped to get some hate mail on this one, but you can successfully violate the 'rules', sometime.
Merc manual states if the prop shaft runout exceeds .005", replace the shaft. Same instructions I'd give if I were selling prop shafts at 400% mark up.
I've successfully straightened two Merc Alpha II prop shafts, using one for three yrs now. Fixing my neighbor's '88 Cobra bent prop shaft, I just did the same. The bends normally occur in the high carbon, high chrome, non-heat treated section aft of the carrier pinion. Very tough steel. I always check the repair with Magnaflux Spot Check crack detecting penetrant, followed by their Spot Check developer.
This one bottomed out my .030" travel dial indicator. Visual said around .050" runout. Back to .0025". No cracks. No $330 new prop shaft for my neighbor. The press is a must for any DIYer.The pressure gauge add is a must for this job. The checking fixture was scrap wood, brass thumb tacks and an inexpensive dial indicator w/base.
