basspirate
Thread starter- Joined
- Apr 26, 2009
- 124
i have a 78 evinrude 140 i'm getting a very weak spark using a spark tester set to about 5/16. if i go to 7/16 as recommended i loose the spark. my timer base is putting out .5 volts, my stator is putting out out 150 volts but the powerpacks are only putting out about 110 volts. both powerpacks are new. i checked the grounds on the powerpacks and the grounds are good. could it be possible the grounds on the coils are bad and that would cause a voltage drop or is there something else it could be? also i tried disconnecting the shutoff wires and it did not change the problem
