Re: weak starter ^
G gulfcoastfisher1 Seaman Apprentice Joined Nov 1, 2005 Messages 39 Nov 5, 2005 #21 Re: weak starter ^
M MCM Lieutenant Junior Grade Joined Jun 1, 2005 Messages 1,201 Nov 5, 2005 #22 Re: weak starter From the battery to the solenoid and engine block should be 4 gauge battery cable, from the solenoid to the starter 6 gauge should work
G gulfcoastfisher1 Seaman Apprentice Joined Nov 1, 2005 Messages 39 Nov 11, 2005 #23 Re: weak starter i fixed it by spraying wd 40 and it runs fine thankyou for the post
S Solittle Fleet Admiral Joined Apr 28, 2002 Messages 7,518 Nov 11, 2005 #24 Re: weak starter I doubt that wd 40 solved your problem. It may have delayed it some. You still need the right wire & clean connections.
G gulfcoastfisher1 Seaman Apprentice Joined Nov 1, 2005 Messages 39 Nov 12, 2005 #25 Re: weak starter well it runs fine so i am not going to try to fix it when it already fixed thank for the post though
G gulfcoastfisher1 Seaman Apprentice Joined Nov 1, 2005 Messages 39 Nov 14, 2005 #26 Re: weak starter and i put wd40 on the starter not the wires
