Bwallis362
Thread starter- Joined
- Sep 21, 2024
- 18
I recently had to splice in a new 8 pin wiring harness from the remote key switch line to my 1985 mercury 35 hp el motor because I had a bad connection and it melted the old wiring. I spliced each of the 8 wires separately with heat shrink solder connectors and then bound them all together with heat shrink electrical rubber. Took the boat out today and it cranked fine and seemed to be working as expected, but unfortunately, now the water coming out of the tell tale is barely a small trickle. I just recently changed the water pump and performed a cooling system flush and before the electrical issues, the water was coming out good from the tell tale. The very small trickle coming out never got hot even after running the motor a short distance and the motor ran fine during that time. Is the problem likely due to a poor connection with one of the wires I spliced? If so, any idea which color wires would likely affect this? (I would rather not have to take all 8 wires back apart and reconnect if I don’t have to.) thanks for any help!
