SnookHunter
- Joined
- Jul 19, 2006
- 29
I have a 2004 yamaha 25hp 4 stroke. I have noticed lately that the stream out of the telltale just doesnt seem to gush out like it use to. It use to shoot out of the telltale and hit the water in a straight line. Now the stream has more of a curve to it and definately doesnt have the pressure it once did. What should I be looking at here?
My next problem I will try and explain the best I can.
When I hook up the hose to the flush port without the motor running I get strong water flow out of the telltale. But a little ways down about 2 feet below the motor there are two openings that water comes out of. Well water use to come out of both openings like normal, but now water only comes out of the bottom opening and only trickles through the top one. Is this anything to worry about?
Thanks for any help you guys can provide.
