Re: Weak water stream from 75 horse Mariner
It could be anything from a worn impeller to a piece of trash in the lines. If you haven't changed your impeller in awhile, I'd suggest starting there. While you have it apart, you can blow some air through the pick-up tube and check and see if your pick-ups on the housing are clogged. Its not much cost to do it all and its much cheaper than an over-heated motor.
