Robertpel9
- Joined
- Apr 20, 2008
- 265
I want to put my boat back in the water this weekend as it is going to be around 70 here in NC and we have warmer weekends coming.
Problem is I still expect below freezing weather regularly. I watched my mechanic winterize my boat as i like to earn how to do things myself and I talked to him today and read on here as well but what i hear and what the manual says are a little different.
He told me all i have to do is the following:
1) Remove plug from each side of engine block and probe with a wire to ensure no blockage is there
2) Do the same with the plug on each side of exhaust
3) Remove large cooling hose at the point that it feeds the impeller (Water Pump)
He said that is it and if i do that i can leave the boat in the water in my slip all i want to as long as i do it each time i am done using it and reconnect everything each time i want to use it until mid march when we are sure temps will be warmer all the time
When i read the manual it tells me i have to remove multiple hoses no just one side of one and that there is a plug in the front as well, etc.
I want to start using my boat again but not if i am going to ruin it by leaving water int he system that can freeze and ruin components and also crack my block
It is a Volvo 4.3GS, can someone please advise as to exactly what i need to do to be able to enjoy my boat in this mixed weather
Thanks in advance,
Robert
Thanks in advance,
Robert
