egldvrbags
Thread starter- Joined
- Sep 8, 2007
- 105
1995 4.3LX, Engine sn: 0F436164, Weber 4bbl Carb, Alpha 1 Gen 2, Thunderbolt IV
Trying to figure out the correct procedure to adjust the idle/mixture for my Webber 4bbl carb.
The service manual 5C-13 step 4 is to put it in forward gear, idle position. Step 6 says to adjust the idle speed to the specified idle RPM in the "tune up specifications chart in section 1-B."
In section 1-B, the specification for idle RPM is 650, in NEUTRAL. There isn't a specification for idle RPM in forward, idle.
Also, service bulletin 97-9 has a different procedure for adjusting the idle mixture.....ie, just in neutral.
Can someone guide me to the proper procedure? And, what should the idle be in neutral AND in forward, idle?
Thanks!
Bags
Thanks!
Bags
