Weber WFB can't remove top of carburetor
NHGuy
My carb is supposed to have 9 screws holding down it's air horn. I only find 8, and the part is not budging. Any insight?
I have only blank unused space in the spot directly in front of the choke plate where a screw is supposed to be.
NHGuy
I found that to be stubborn, it would not turn on my first go round. Maybe I might warm it up a bit with a heat gun.
on edit, nope. I locked a couple of nuts on the air cleaner stud, nothing. Then I went vice grips, nada.
I'm stopping to think and avoid breaking stuff!
NHGuy
But you are right, all the pics in the manual have it with the stud removed. Here I go back with the heat. I'm going to put the outer screws back in to see if they help me free the center stud.
NHGuy
The heat did it. Bet it's never been open since 1997.
