Re: weed eater problems
can you keep it running if you play with the choke at the same time you give throttle? if so, you are starving for fuel. after you replace the plug and clean the filter, check the adjustment screws per fat fanny. turn them clockwise until they stop, count the turns in. then go back out that many turns. start by going 1/4 turn farther out at a time until you get results. if you dont, try going leaner a 1/4 turn at a time, could already be too rich. if this does not solve your problem try a rebuild kit and parts cleaner soak. is there a fuel filter on the end of the fuel line? hope this helps.
