pooh_b_21632
Thread starter- Joined
- Jul 26, 2009
- 31
I am going to weigh my options here in my opinion we should put in four new pistons the $500-700 or so to do it is less than another used engine (and less than someone elses headaches IMO) Hubby does not want to rebuild he wants to purchase another used engine.
We have a 1990 120lx90b long shaft that the number three piston came apart on. The damage was quick leaving one tiny mark on the number 2 cylinder wall which still had 125lbs of compression at the time we discovered the damage. Boat still ran with the damaged piston but had a slight misfire (loss of compression). I feel we could remove the flywheel, open the crankcase, replace all four pistons, and hone the number 2 cylinder with the block attached to the leg (if it needs to come off the leg he will not do it) or maybe even just leave it alone it did have good compression after all the way it was.
Hubbys concerns:
1. how to get the piston off the rod
2. how to keep the bearings in while reconnecting the rod to the crank
3. how to time the engine and what to be careful of while the flywheel is off the engine (He doesn't want to spend the money for new pistons/rings and gaskets then its out of time and the pistons hit the head) causing more damage
I am willing to do half or more of the work myself but I can only do what I know how to do.
Step by step instuctions would be great I have a manual but its a bit confusing and all over the place.
As of now the head is off, the carbs and reeds are out, and the number three piston is out. Tonight I plan to remove the other three pistons and see what I have as far as damage.
The guy I buy my parts from told me he knows we can do it and it would be stupid to not put new pistons in it, as much time and money I have spent working on it so far.
So I can spend around $1000 for a motor with potentially the same problem, or I can spend $1000 to fix my motor that I know has a good lower unit and everything but the pistons looks good to me.
Hubbys concerns:
