Re: weight differance between a 115 & 150
I don't know the difference, I have never had one of these styles. I believe I have crossflows but would not bet the farm on it. I now have 2 1979 motors one Johnson 140 and an Evinrude 115. When did they start the loopers? I need to find out if the length of the "shaft" the distance from the top of the mounting hole to the cavitation plate is longer is the same on the 20" motors. Well that makes no sense, it should be the same,....does the centerline of the prop sit lower on a 20" v6 vs a v4 given that my v4 has the smaller lower unit?
