maineiac5586
- Joined
- Feb 14, 2009
- 828
So my new to me 1987 johnson 55 hp commercial tiller motor is exhibiting a weird issue. When I try to start it just pops loud through the exhaust and won't fire up. The small wires that go to the coil posts are connected the right way at the coil (orange wire with blue stripe on the upper coil) orange wire with green stripe on lower coil. I was using a spark tester and hooked the bottom coil lead to the tester while the other end of the spark tester was plugged into the top cylinder spark plug. It fired right up like this. So I took the tester off and made the plug wire from the bottom coil go to the spark plug of the top cylinder and upper coil firing the lower cylinder. It started right up and seems to run fine. So basically the coils are connected to the wrong cylinders allows it to run. I switched back to the proper coil for proper cylinder and it wouldn't start just backfire and pop through the exhaust. Never seem this before. Please help
