GaJeff
Thread starter- Joined
- Jul 9, 2012
- 149
I have an 81 Citation 19.5' Bow Rider. It's all original, same year I/O Mercruiser 120 and MC-1 drive. Over the weekend there were fireworks over the river and the locals like to get on the water to watch. We headed down there and as it got dark I turned on my NAV lights. I noticed as we rode they started to flicker. I was a little worried because its dark and I'm about 2mi. away from the dock. Kept any eye on my volt gauges and it seemed to be fine... Ok must be a short somewhere.
Today I'm checking it all out and the only time they flicker is when I rock the boat side to side. I'm checking EVERYTHING... Under the dash along the sides all the grounds... All the powers. Nothing, I take apart my light and its fine. Everything is fine.
Now I'm greasing my drive and the hinges. Move the drive side to side and there it goes again. WTF?
So I get back in the boat and check back there. I wiggle the connecting rod from the steering cable to the arm for the drive and there it is. Why? Not exactly sure but that rod is completing a ground somewhere to make my lights work. On the transom plate I put a flexy ground strap to the engine and problem solved. I'm not sure what's going on here or why but it fixed the issue. Maybe someone on here knows and would like to share. If your ever in a situation like this check your grounds from your drive to your engine.
Jeff
Jeff
