oops!
Thread starter- Joined
- Oct 18, 2007
- 12,932
Re: weird house boat problem
thats the problem austin....some idiot painted the inverter box and we dont know what it is.....when you take the cover off....there is nothing.,...no writing, no numbers....ziltch
Oops, a couple suggestions.
1. Get a battery hydrometer (around $10) to test each cell of each battery. This is far more accurate than any voltage reading and will instantly show if the battery has a bad or questionable cell. (All cells chould be within .05of each other.)
2. Hate to say it but I suspect there is something wrong with the inverter. Any inverter made in the last 15 years SHOULD have a warning at anything below 12 volt DC input and should shut itself down some where around 11 volts input. Just a SWAG,,, the sensing diode (usually one or more zener diodes) is shorted and not shutting the inverter down and could very well be what is draining the batteries so quickly. If you can get me the manf. and model I can do a little research on it and suggest further testing procedures.
