dgopetactical
- Joined
- Jul 3, 2007
- 509
88 mercruiser 5.7 alpha 1
I bought this boat in april. other than little things the boat runs good.
when I put her on muffs and I get around 1,500 rpm I just dont thinks it sounds right it sounds like a grinding noise (Brawwww) or like running a peice of wood i a picket fence comming out of the exhaust.(hard to explain).I sounds like it gonna blow up if i would take it above 1,500(which I was informed not to do on other post.
I have heard other boats on muff when they rev and they dont sound like this.
The guy I bought it from did not even flinch when it was on the muffs when I bought it so I figured it was normal. At idol its sounds fine It runs good in the water im missing 300rpm at wot but Im working on that withs dons list.
is this sound normal any ideas.
I grease all visiable fittings.
all fluids are clean and have been changed in june.
And yes it is out of gear when doing this.
Thank you
Thank you
