Weird Thunderbolt V problem, driving me mad
hulakai
Hi all...
I've been reading and reading and reading, and while I have found some ideas to try based on other T5 posts, I'm going to post my issue now and hope like heck someone responds soon because I have no faith that the things I'm going to look at this afternoon are going to solve the issue. I apologize for this lengthy post, but as you read you'll understand why it's so long. It's a very strange issue and I've already done some testing and troubleshooting which I wanted to be very detailed about...
I have twin '99 Merc 5.0 MCM motors (2 bbl carbs with T5 ignition). Sorry, I don't have the serial numbers handy but I don't think we need them for this...
One motor (starboard) runs fine, the other won't make power and won't rev above 2800rpm. It also idles fairly rough, and stalls when in gear at low speed. This all started last year so I did new plugs, wires, cap and rotors in the spring, and over the winter I had my mechanic check the distributors out to make sure the sensors were working. He did NOT check the modules or whatever the built-in component on the distributors is called. (I am NOT referring to the control module and knock sensor that is mounted on the exhaust riser)
I redid the timing yesterday, with a brand new digital timing light, being fairly certain I had not done it right originally. I was right and reset the timing to 10 degrees BTDC on the first motor (the one that runs well) and everything went fine. Runs great now (although the idle mixture/speed screws are still black magic to me so I just do it by ear for smooth idle without unnecessary richness). Still not the weird part....here we go....
When I checked the port motor I COULDN'T GET A CONSISTENT SIGNAL TO THE TIMING LIGHT FOR CYLINDER 1. It kept going on and off for periods of time (5-10 seconds). The motor starts fine, and it revs fine (no load), In fact, when I rev it the signal to the timing light comes back and seems to stay steady, but as soon as it returns the idle the timing light will show all zeroes as if the engine is off, then it will come back, then it will go off, and so forth. The engine idles rough....not horrible, but not silky like the other one. So probably a weak coil giving me a weak signal, right? Not so fast....read on.
Here is what I tried last night, along with some ideas that I'm going to try today:
- Verified timing light works properly on good motor, several times throughout troubleshooting. Definitely not the light.
(Now it gets weirder)
- I put the timing light on number 8 (right beside number 1), and it's also intermittent. BUT IF I PUT IT ON A WIRE ON THE OTHER SIDE OF THE DISTRIBUTOR, IT WORKS CONSISTENTLY.
*Theory #1 - something wrong with cap. Today I'm going to try number 2 which is immediately on the other side of number 1 and see if it is inconsistent like number 8 is, and I'm going to swap caps with the good motor and see if the problem moves with the cap.
- I swapped the coil with the one from the good running motor. No change, so I returned the coils to their original motors.
- Next I swapped ignition modules and knock sensors (the ones mounted on the risers). No change, and the good motor runs fine with other module. I left modules swapped.
- Next I swapped the rotors. No change. Good motor runs fine with other rotor. I left them swapped.
- Next I swapped the #1 spark plug leads. Still no change to intermittent timing signal and good motor runs fine with wire from other motor.
So now I'm at theory #2 (and the main question I have for you guys):
The voltmeter on dash says port (the bad motor) alternator is NOT charging. It was supposedly a new alternator when the boat was bought last year (that's a whole other story about lying brokers for another day) and it LOOKS new, but it was reading low last year too. I assumed it was a bad gauge last year, but I put in all new gauges over the winter and it's still reading low. The starboard side reads as it should. I checked the wiring on the back of the alternator and it looks fine....tight and the wires are in the right places.
Could a lack of power from the alternator cause the ignition problems I'm having, even with brand new, fully charged battery?
While waiting for (hopefully) an answer to that, today I am going to swap alternators and see if the problem follows the alternator.
I read in another post from RobertD ("Found an electrical gremlin!"), who was having an ignition problem, that he ended up tracing the purple wire from the alternator all the way back to the coil (I didn't realize that's where the purple wire goes....but I'll assume he's right until I learn otherwise), and he found a weak spot in the wire before he got to the coil. He replaced the wire and his problem went away. That seems to boost my theory that the alternator issue is affecting the ignition.
I've never connected the two issues because I know on a car you can run for quite a while without a working alternator if your battery has enough juice to keep making spark. Are boats/TB5 different in that regard?
I'm hoping someone has seen this weak timing light signal issue before, because I'm quite certain that it's also indicating weak spark as well, and that's why the motor bogs and won't rev/make power. I didn't make the connection with the alternator issue until late last night...perhaps that should have been my first clue.
Any ideas/help are greatly appreciated. Thanks
Kevin
p.s. Oh, as a side note and just to make sure I'm not missing something....it's ok to have ONE starting battery/bank for both motors, right? i.e. I have two banks, one for the house and one for the engines, and both engines pull on the same battery/bank for starting. I ask because I wondered if it's ok to have two alternators charging the same battery/bank. The alternator wasn't charging long before I made that change, but just thought I'd ask anyway in case it's related somehow.
Re: Weird Thunderbolt V problem, driving me mad
try changing the lead from the coil to the distributor with a know good one. also attach a jumper cable to the head with the number one spark plug and attach the other end to the battery negative and see if that makes any difference. Im not sure if you can hook 2 alternators to one battery as they will play with each other especially the voltage regulators. (kinda confused that the volt meter would read different if both engines were attached to the same battery). Also while you are there it would be a good idea to find the ground cable on the motor then remove and clean the cable end and the mounting point then re-land it. I would disable one alternator until some one tells you that you can run both on one starting battery as ive never heard of this being done.
alldodge
Just a bit long and sounds like it was needed, but lets see what we can discover. The two alternators (ALT) should not be going connected back to the same point. ALT's work very well but have very minute differences which cause them to turn on (start charging) at different levels of charge. It appears this could be one or two of your issues if it is the case. If one ALT will turn on just slightly different then the other which will cause the other to switch off and may then do to voltage changes cause the other to turn off then back on. The constant changing will cause the weaker to stay off most the time (your port side). This constant on/off of the Port ALT could be causing issues with the ignition modle and may show up in your timming light. Try disconnecting the alternator and see if the timming light issue changes.
The simplest way to setup dual ALT's is to have one charge the house bat and the other change the starting bat. You can tie the Gen into the start if you have one. Have battery switches or relay combiners to put them together if the need arrises.
So far as no power, this could be not enough fuel, timming (as you mentioned), air flow. My first thought was a knock sensor but you said you switched them and it didn't help. Did you try disconnecting the knock sensor to see if your RPMs would come up?
The purple wire can and it most cases goes to the field winding or the ALT. This is the wire when the key is turned to ON it applies 12V to the Ignition modle, ALT, and other components to run the engine. A bad spot or connection in this woire can cause many issues.
hulakai
Thanks for the quick replies. I'm at the boat now.
In my original post I forgot to say that I swapped the leads from the coil to the distributor too....with no change.
I'm not 100% sure what you mean by connecting a jumper from the #1 spark plug lead to negative. Do you mean connect the lead to negative with the plug disconnected, or jam a jumper in with the plug wire at the distributor and connect it to negative?
Re-doing the ground on the block is a great idea and I'm going to do that now.
As for the alternator issue, let me expand on that. The boat has two battery switches in it, labeled "Engine" and "House". I have a single cranking battery, and I have two identical deep cycle batteries wired in parallel. I connected the cranking battery to "1" and the house batteries to "2" on BOTH switches (used jumpers to go from the first battery switch to the second). Both engine cables come off of the output pole on the Engine switch, and the house cable comes off the output pole on the House switch. So now I can select which bank to use for the house and engines. It wasn't until after I did this that I realized it meant both alternators would be sending power back to the output pole on the engine switch, which means they are connected to each other.
How is this kind of two bank set up achieved on other boats? I like the idea of having each alternator charge a different bank. Do I just disconnect the main lead coming off of the alternator from the starter and run straight to the House battery switch? Do I need to do anything with the other wires coming off of that alternator? I don't mean to take this thread sideways but I'm still wondering if that is related to the weak spark issue (if this is really about a weak spark).
I'm going to disconnect one alternator for now, and redo the block ground.
alldodge
Not knowing how your boat is setup is the issue to full understand the best way for you. You should run the ALT's direct to the batteries and can be done via switches or relays, but that being said it needs to be done correctly. The images below show a setup for dual batteries and dual using an isolator between ALT and Bat. With being able to connect both batteries together from either switch can cause issues and I have concerns. The best way is to have only ON/OFF switches for each side and have one other to combine. The combiner on many boats is accomplished via a relay so there only needs to be a small push button switch on the dash panel that can be used when needed to start up.
Google Image Result for http://continuouswave.com/whaler/reference/graphics/wiringAlternate485x347.gif
running a jumper cable from the head to the negative of the battery. I have read that there are cases on v6 and v8 motors where one head due to corrosion etc has a problem with a poor negative. The high voltage that goes to the plug has to go to the block then back to the negative wire to complete the circuit so there are cases where all the plugs on one side are weaker than the plugs on the other side of the block so a quick test is to use a starting cable and go from somewhere metal on the head (cleanest part you can find) to the battery negative as this will ensure that there is a good negative path for testing
hulakai
Ok...so I disconnected the alternator (the output lead only....I left the other two connected). For the heck of it I tried the timing again.....and now I have steady signal on lead #1.
Is it possible that my stupid mistake with the battery/alternator wiring was causing the ignition problem?
I haven't taken the boat out to see if I can get power from that motor now that the timing is right, but I'm skeptical. The other motor was off on timing too but it would rev at least.
Still hoping to learn if I simply need to run a wire from the output of the alternator to the house batteries or if there is more to it. The voltmeter on that motor is reading even lower now.....should that change when the output is connected to something again, or could the alternator be shot from the wiring mistake?
alldodge
Do not just remove the ALT main wire, this can cause your ALT to blow the diodes in it. I'll reply shortly with more
hulakai
Thanks very much for the wiring diagrams Dodge. I thought about maybe needing isolators...I'll definitely study those links.
Glenn, great point about the possibility of a weaker ground on one side. This was a saltwater boat and there is definitely a lot of corrosion evident. I'll run a ground cable from the one head over to the main connection point on the other head (solid connection there with one zero gauge cable back to batteries and TWO zero gauge cables to the other motor. Can't hurt.
Now I'm just trying to get psyched up to go out and see how she runs. This boat has been one nightmare after another and I'm tired.....soooo tired. I was supposed to take some buddies out for opening day (Bass) this Saturday. Not looking good at this point.
alldodge
Let me just work on the battery charging issue only for now.
What kind of boat do you have?
What kind or model of battery charger do you have (how many banks)?
How is the battery charger connected to the batteries?
Does the wiring from the charger go through an isolator?
hulakai
It's a 1999 Bayliner Ciera 3055. It has a Promatic 30-3 charger, that appears to be a 3 bank charger with 30 amps per bank but only 2 of the 3 outputs are wired.
The charging leads are connected to the batteries at the battery switches on the same poles that the batteries are connected so essentially they are connected directly to the cranking battery and the house bank.
There are no isolators in the circuits.
I already had the engine running without the alternator connected. Have I already blown the diodes? I should have realized....i know that you can't turn a battery switch to OFF with the engine running. Just another dumb mistake. :-(
alldodge
You might not have damaged the ALT, but the best way to disable at ALT is to unplug the field wires (purple). I'll work on something and try to put it into a JPG so you can look at it. So I take it you do not have a Generator which is fine?
Most baterry switches with the both connection has an microswitch in them to disable the ALT when they are being switched. If you want to know of your ALT is OK just reconnect and start the engine. Connect a meter to the ALT output and if you get 14V or so your good, otherwise it's fried.
Will return with a diagram later
hulakai
You mean generator vs alternator, right? The boat has a Genny, but the engines have Mando alternators. Before I disconnected the output on the alternator I tried putting my meter on the output and the ground on the alternator and the positive probe sparked! That shocked me as I've never had a meter cause a spark before. I stopped right there in case testing that way was incorrect. Maybe the diodes are already fried and that's why it sparked? It would explain the low reading on the voltmeter. The battery wiring was f$%&d when I got the boat to its quite possible it was already toast.
alldodge
Yes having a Generator is somthing we need to design the wiring correctly. Does the GEN have it's own battery or does it use the start battery?
If you got a spark on a meter prob something is way wrong. A spark on a high impedance meter probe would mean it probably fried your meter. The meter set on volts setting should never cause a spark. Diodes open up when they fry and a spark should not be seen on a meter. More than likely there are other issues which will come out later during testing and troubleshooting.
hulakai
The Genny is currently connected to the same battery switch as the engines. I wonder if the sparking has anything to do with the fact that two alternators were essentially connected to each other....but alternators is one thing I know NOTHING about. I just know that meters, as you say, should never spark.
alldodge
The file attached is how a 3 bank battery would be setup. You would only use one switch to combine the house and start batteries. If you keep it with 2-banks keep the Generator with the start batteries. If an isolator is used it would be run from the starter ALT to the Isolator then split off between the GEN and Start battery.This would isolate the two batteries.
The battery combiner switch can be used manually as a switch or as a relay.
hulakai
Thanks very much Dodge. Very nice of you to spend so much effort on this.
Question: when connecting ALT 2 to the House batteries, do I leave the purple and red wires as they are or do I have to change something?
alldodge
One or both of them probably go to a circuit like your bildge pump and must be connected directly to the battery or on the side of the switch which will stay hot always. So not fully knowing I would leave them as they are.
