Kevin Morin
- Joined
- Nov 7, 2009
- 78
Welded Skiff Remodel; Framing the Upper Transom
If there is no builder's model or plans to use for plate take offs, the only way to fit hull panels to their final shape is on the boat. To fit a panel that would butt to the pipe along the sheer, and fit to a flat bar edge at the median [lower edge of the top panel] we had to put up a forest of small 'sticks' of scrap tacked into the surface. These held the trial sheet blanks into the eventual surface of as the edges of the blank we marked, removed, cut and replaced to marked again. Slow and strenuous because the material was stiff for the curves.
Here is a photo from the starboard side aft looking toward port, of the lattice of sticks we tacked in to hold the blanks while they were scribed. We used heavy craft paper to make an original pattern so the metal could be put up and marked as little as possible.
Same view but from the other side of the hull,
This view, inside the hull looking aft at the temporary framing and the lower after panels tacked in, show the T bottom concept about as well as we'll see inside this skiff.
Cheers,
Kevin Morin
Cheers,
Kevin Morin
