Well look what I found today
chaparall villain 2
Re: Well look what I found today
man now thats a blown head gasket .. while you have the head off i would have it checked for warpage and surfaced if nescesary i see alot of warped heads that need surfacing at the machine shop .... usually not to expensive to do when compared to gettin it back together and havin it happen again ... good luck
moparmatt
On the exhaust manifold side do i need a new gasket or is high temp red rtv acceptable? What sealant should I use on the head bolts?
6meter
New gaskets. For the bolts I use head gasket cement.
stonyloam
Perfect seal for the bolts, NAPA (Permatex) aviation sealant a good substitute. Depending on the age of the engine you might consider hardened exhaust seats, your machinist should know if you need them.
moparmatt
Took the head to the machine shop today to have it surfaced. I got a call from the machine shop to come look at my head it had 2 cracks in it he found when he was magnafluxin it. When is this nightmare gonna end? lol
