wellcraft help needed
Ok so new to the site. I have recently inherited at 79 wellcraft 310 suncruiser. My question is, this boat sat out (in ohio) unwinterized since october. I have a mechanic coming to look at the engines but there is about 12 inch of water in the bilge. As the batteries are dead I went looking for a drain plug and could not find one. Can anyone help here?
thanks from a noob at this
Re: wellcraft help needed
Ayuh,.... Welcome Aboard,.... I'm guessin' you've got Alot more work ahead of ya, than you will believe....
The drain plug is always at the lowest point in the hull...
Crawl under it, 'n ya oughta be able to find the Hole,...
Then look inside the hull for the plug...
found it. it was inside, underneath the steps that lead to the cabin. yuk. I have an engine question that i will post in the merc engine section.
