89cruisers
- Joined
- Jul 11, 2005
- 190
well after new plugs and wires, and a new axle I took the nova out today. Wasn't able to get it to go above 3800rpms and got about 38mph out of it. It was suggested trim could have been off in the previous post, I move the trim all over the place and still never got above 3800 rpms and 38mph according to the gps. To go over again what's been done, had a 302 in the boat last year hooked up to a 233 drive which is a 1.3 ratio due to previous owner taking the factory 351 out and putting in the small 302 and was only getting up to about 3200 rpms. Put in the 351 this spring, new ignition (points rotor condenser wires plugs coil), which is advancing properly, good compression, 16 pitch 4 blade prop, carb is getting plenty of fuel (4 barrel) which the secondaries are opening, triming the drive around didn't help any. I did notice today that when cruising at 2800 rpms, and then pushing the throttle to WOT That the rpms from 2800 to about 3200 will jump up immediately which doesn't seem correct. Anyone have anymore ideas?
