Wellcraft Sportsman makeover
Status
Not open for further replies.
Rich Hargis
I had ideas to replace the transom on my outboard version of the Sportsman 248 with a full transom and Armstrong bracket.I gathered all the info I could get for doing the replacement,then I happened to find an Inboard/Outboard version of the same boat for a super low price,plus it was 2 years newer.It was a no brainer ,get the newer one that was in alot better shape.It had the OMC stringer 800 in it,that was going to come out anyways.The transom was solid as a rock after a few exploritory holes.First thing I did was take it to Pacific Yacht Towers and had a hard top put on it.Then I stripped everything off the old boat and to it to the dump.Here are som pix.
Big Sarge
Re: Wellcraft Sportsman makeover
congratz, hope there are no more problems that arise.
Rich Hargis
I'm in San Diego and had to drive to Florida to pick the boat up.
Big Sarge
now that sucks and fuel musta been horrible
Rich Hargis
Cat.D9 vs Wellcraft
Guess who won!
Rich Hargis
I went back there in January when diesel wasn't as high as it is now. Still cheaper than having it shipped out
Rich Hargis
Taking apart the new one
Rich Hargis
Preping to fill the hole
Rich Hargis
I beveled the opening on both sides to lock in the pieces that are sandwiched together to plug the hole.Then a full sheet was laminated to the inside of the boat as well.I used epoxy for all the constructon including the cabosil and micro balloons.I wanted to see how the bracket would look ,so I bolted it on for a while. It will come off so I can paint the transom over the weekend.Next I will fabricate a stainless knee brace system and bolt it to the stringers or bed mounts from the inboard engine.I figure the brace will support the majority of the load and the marine plywood and fiberglass is basicly just to keep the water out.
Big Sarge
haha I actually think I enjoy fixing boats more than I do driving them on the water.
Rich Hargis
Got 2 coats of paint on the transom,will bolt on the bracket in a few days
Rich Hargis
Got the motor and bracket mounted after work today
Rich Hargis
Tore out the old shifter cables and the steering cable,plus some unused wires under the gunnels today.Need to run new hydraulic hoses and shift cables next.
Rich Hargis
Well a year has gone by and I have worked on the boat again for the last few weeks.Installed all new wiring and hydraulic lines.Mounted Radar,GPS and VHF antennas.I was able to mount the transducer on the keel so I did not have to use a fairing block.I had to add about 8" of deck to each side of where the floor was cut out for the engine. I kept the removable center deck from the outboard version boat I had and will use it on this one. I hope to splash the boat in a week.
Rich
Rich Hargis
Made some more progress
Rich Hargis
It Floats!
KD Fisherman
Congrats! That has to be an amazing feeling to have it on the water. That is one great looking vessel.
Cheers,
Kyle
berry79
Nice job. Now it's time to go fishin.
Status
