Wellcraft trim tabs
SOUTH JERSEY WALT
Need info for putting trim tabs on 2012 232 fisherman with 250hp outboard
what size is best . Looking for info from someone who has done this
not alot flax about this and that.
Tabman
iboats.com Partner
Re: Wellcraft trim tabs
Either Bennett 10" x 12" M120s or 12" x 12" Bennett or any other brand would be great choices for your 232. If you have a swim platform the M120 is the way to go since it has short actuators (rams) that will likely be easier to fit.
Tabman
iboats.com Partner
Walt,
I am not sure why you are choosing the ST12 Sport Tabs. They are dual actuator Trim Tabs usually used on higher performance boats. The standard 12 x 12 or M120 will be just fine, cost less and take less time to install. But some folks like the black powder coat on the ST12 and if this is why you want them, I can understand that, they look great!
Like all things, the best thing is to measure twice (or three times) so you only have to drill holes in the transom once!
If you go to our website Bennett Marine: The world leader in trim tab innovation, quality and service you can find the installation instructions for all of our kits. Also here is a link to a video Bennett Trim Tabs Video Player that shows the installation of the M80/120s, but the general aspects pertain to all of our kits.
Look them over and let me know what questions you might have.
SOUTH JERSEY WALT
i am not sure why you are choosing the st12 sport tabs. They are dual actuator trim tabs usually used on higher performance boats. The standard 12 x 12 or m120 will be just fine, cost less and take less time to install. But some folks like the black powder coat on the st12 and if this is why you want them, i can understand that, they look great!
If you go to our website bennett marine: The world leader in trim tab innovation, quality and service you can find the installation instructions for all of our kits. Also here is a link to a video bennett trim tabs video player that shows the installation of the m80/120s, but the general aspects pertain to all of our kits.
tabman good info on video boat has 8ft 8in beam will have to measure in spring for largest one that will fit thanks
