machine_nut
Thread starter- Joined
- Aug 7, 2011
- 8
Looking to identify the model of this Wellcrat boat, it is 25' with a 350 engine.The hull number is messed up and hard to see,but as close as I can tell it is a 1979, last diget in hull number are 79 and that is supposed to be the year from what I have read. May hav been modified look like a plane fishing boat and was told that is what it used for (tuna) fishing.
Hny help woul be good it is pretty solid.
Thanks
Machine nut
Also found these numbers if you can identify
Engine tag on Valve cover transom tag in engine compartment Out Drive
5.7 Prod Code 3868404 Prod Code 3868164
4110133260 Type SX-C1 Type DP-s
3868429 S/n 4111558274 S/N 4112020772
Have Problem deciphering numbers
Thanks
Machine nut
