We're stuck! 6hp Evinrude
Abu
So we grounded the prop on a 6hp EVINRUDE and then it jammed in forward drive.couldn't move the lever into neutral or reverse.<br /><br />So we took off the prop and then the bottome unit without knowing waht we were doing. The problem appears to be behingd the final drive shaft from where I presume the reverse forward gears are controlled. However now can't get the final drive shaft out of the lower unit as there is this annoying worm drive type cog that is preventing the extraction of the final drive shaft and the rear of the cogs that it is attached to. How do we get the dammed thing out??<br /><br />Does the shaft come out of the rear cog or is there some other trick involved? Any idea what is broken why the thing wont engage any other gears?<br /><br />Hope someone can help - thanks<br /><br />Abu
JB
Re: We're stuck! 6hp Evinrude
Give us a little more information, Abu. If you don't know the year, give us the model #. Then we can find the correct diagrams, etc. to help you.<br /><br />Standing by.<br />JB :)
Abu
J.B.<br /> can not find a reg # but engine is prob fom 80's. We also have a 2000 model 6 Johnson with the same part #s and can not find reg on that if you need it to help i will need help finding it.<br /><br />thanks abu
joejoe
Hi, ABU YOU CAN LOOK ON THE FROST PLUG THAT IS WHERE I WAS ABLE TO PROVIDE THE INFO TO THE VOLENTEERS HEAR TO HELP I'D MY MOTOR.
Abu
where is the frost plug
joejoe
Located on the engine block should be a round metal disk. that will have numbers on it.
joejoe
other places to look ---check the following locations: <br />the stern mounting bracket <br />the freeze plug <br />the flywheel <br />the side of the cylinder assembly look.
Abu
Thanks Guys, found it!<br />Ser no B24220010<br />model no E6RESR<br />Made in Belgium!<br /><br />My guess c 1985<br /><br />Does this help?
