West bend 80hp Mix ratio?
crazy_s_dime
hey, do any of you know what oil ratio that im supposed to be running? I think that its supposed to be a 50:1 mix, but i dont have anything backing this up. its a 1964 West bend/chrysler 4 cylinder 2stroke
CATransplant
Re: West bend 80hp Mix ratio?
I couldn't find anything about the ratio. Most everyone switched to 50:1 right about then, but...
You might want to run 40:1 or even 32:1 until you find out for sure. You'll never go wrong with too much oil, but you sure can with too little. It would be a real shame to see that nice old engine ruined.
Keep looking for the specs, but play it safe until you find out for sure.
steelespike
My 1970 after market service manual states 24:1 with an asterix.
Paragraph says 48:1 carefully mixed.Making sure tha idle mix screws are adjusted carefully with any error on the rich side.Also the correct high speed jet is to be used.
I would think that TCW3 rated oil is miles above the oil available in the late 60s early 70s
CATransplant
OK. I think I'd probably run no leaner a mix than 32:1 in that outboard. Actually, I'd run 24:1. No harm to that, and an old engine needs all the help it can get, I think. I don't know what type of bearings it has, and if they're plain bearings, the heavier mix would help protect them.
I'm very conservative with this stuff. I run 40:1 in my 1992 Johnson 6hp. It smokes a little more, but...what the heck...
