bollerwagon
Thread starter- Joined
- Oct 15, 2020
- 102
Finally, I´m proceeding, the block will be machined. I plan to exchange and upgrade some parts. I have a list what I want to purchase for that. It would be great if you could comment and throw some wisdom/experience at me.
Questions would be:
- whats missing?
- whats not necessary to change because old part can be reused
- is the chosen part a wise choice?
Questions would be:
- whats missing?
| Pos | item | Part # | Link | |
| 1 | Fel-Pro Rear Main Seals | Fel-Pro BS40656 |
Fel-Pro BS40656 Fel-Pro Rear Main Seals | Summit RacingFree Shipping - Fel-Pro Rear Main Seals with qualifying orders of $99. Shop Rear Main Seals at Summit Racing.
| 2 | Hauptlager Clevite P-Series Main Bearings | MS-909P |
Clevite Engine Parts MS-909P Clevite P-Series Main Bearings | Summit RacingFree Shipping - Clevite P-Series Main Bearings with qualifying orders of $99. Shop Main Bearings at Summit Racing.
| 3 | Clevite P-Series Rod Bearings | CB-663P(8) |
Clevite Engine Parts CB-663P(8) Clevite P-Series Rod Bearings | Summit RacingFree Shipping - Clevite P-Series Rod Bearings with qualifying orders of $99. Shop Rod Bearings at Summit Racing.
| 4 | Sealed Power Cam Bearings | SLP-1235M |
Sealed Power 1235M Sealed Power Cam Bearings | Summit RacingFree Shipping - Sealed Power Cam Bearings with qualifying orders of $99. Shop Cam Bearings at Summit Racing.
| 5 | freeze plugs | SUM-G1581 |
Summit Racing SUM-G1581Free Shipping - Summit Racing SUM-G1581 with qualifying orders of $99. Shop Engine Expansion Plugs at Summit Racing.
| 6 | Speed-Pro Hypereutectic Excess Pistons 020 | SLP-H423DCP20 |
Sealed Power H423DCP 20 Speed-Pro Hypereutectic Pistons | Summit RacingFree Shipping - Speed-Pro Hypereutectic Pistons with qualifying orders of $99. Shop Pistons at Summit Racing.
| 7 | Sealed Power Performance Piston Ring | SLP-E-251K20 |
Sealed Power E-251K20 Sealed Power Performance Piston Ring Sets | Summit RacingFree Shipping - Sealed Power Performance Piston Ring Sets with qualifying orders of $99. Shop Piston Rings at Summit Racing.
| 8 | COMP Cams High Energy Hydraulic Roller Lifters | CCA-850-16 |
COMP Cams 850-16Free Shipping - COMP Cams 850-16 with qualifying orders of $99. Shop Lifters at Summit Racing.
| 9 | Timken Timing Cover Seals | TMK-9845 |
Timken 9845Free Shipping - Timken 9845 with qualifying orders of $99. Shop Timing Cover Seals at Summit Racing.
| 10 | Melling High-Volume Oil Pump | MEL-M55HV | ||
| 11 | Fuel Pump Block off plate | SUM-420001 |
Summit Racing SUM-420001Free Shipping - Summit Racing SUM-420001 with qualifying orders of $99. Shop Fuel Pump Block-Off Plates at Summit Racing.
| 12 | Push rods | measure first | ||
| 13 | Fel-Pro Performance Marine Head Gaskets | FEL-17030 |
Fel-Pro 17030Free Shipping - Fel-Pro 17030 with qualifying orders of $99. Shop Head Gaskets at Summit Racing.
| 14 | hed bolts | ARP-1343601 |
ARP 134-3601 ARP High Performance Series Cylinder Head Bolt Kits | Summit RacingFree Shipping - ARP High Performance Series Cylinder Head Bolt Kits with qualifying orders of $99. Shop Cylinder Head Fasteners at Summit Racing.
| 15 | Exhaust Manifold Gaskets | FEL-1405 |
Fel-Pro 1405 Fel-Pro Performance Exhaust Header Gasket Sets | Summit RacingFree Shipping - Fel-Pro Performance Exhaust Header Gasket Sets with qualifying orders of $99. Shop Header and Exhaust Manifold Gaskets at Summit Racing.
| 16 | water pump gasket | SCE-21101 |
SCE Gaskets 21101Free Shipping - SCE Gaskets 21101 with qualifying orders of $99. Shop Water Pump Gaskets at Summit Racing.
| 17 | Torque Fastener Assembly Lubricant | ARP-1009909 |
ARP 100-9909 ARP Ultra Torque Fastener Assembly Lubricant | Summit RacingFree Shipping - ARP Ultra Torque Fastener Assembly Lubricant with qualifying orders of $99. Shop Assembly Lubricant at Summit Racing.
| 18 | Silicone Gasket Maker | PTX-82180 |
Permatex 82180 Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker | Summit RacingFree Shipping - Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker with qualifying orders of $99. Shop RTV at Summit Racing.
| 19 | Reluctor ring | ADO-10190917 | ||
| 20 | assembly prelube | CCA-153 / SLP-55403B |
Sealed Power 55-403BFree Shipping - Sealed Power 55-403B with qualifying orders of $99. Shop Assembly Lubricant at Summit Racing.
| 21 | Spark Plugs BKR5EIX | MSD-3724 |
MSD Ignition 3724Free Shipping - MSD Ignition 3724 with qualifying orders of $99. Shop Spark Plugs at Summit Racing.
| 22 | Roller tip rocker arms | CCA-1418-16 |
COMP Cams 1418-16 COMP Cams Magnum Roller Tip Rocker Arms | Summit RacingFree Shipping - COMP Cams Magnum Roller Tip Rocker Arms with qualifying orders of $99. Shop Rocker Arms at Summit Racing.
| 23 | Valve springs | CCA-981-16 |
COMP Cams 981-16Free Shipping - COMP Cams 981-16 with qualifying orders of $99. Shop Valve Springs at Summit Racing.
| 24 | Valves Exhaust 1.60 | SUM-V8010-8 |
Summit Racing SUM-V8010-8Free Shipping - Summit Racing SUM-V8010-8 with qualifying orders of $99. Shop Valves at Summit Racing.
| 25 | Valves Intake 2.02 | SUM-V8002-8 |
Summit Racing SUM-V8002-8Free Shipping - Summit Racing SUM-V8002-8 with qualifying orders of $99. Shop Valves at Summit Racing.
| Timing Chain? |
