Hello,
What, tulipped valves?? How? How low for how long?
Recently got new 4-blade prop to test due to sluggish low end performance. With original 3-blade prop engine would turn 4600rpm on the 4200-4600 recomended range.
New prop went up 1" pitch and engine lost 700 rpms,
It now runs WOT @ 3900, maybe 4000. Obviously that is outside the minimun recomended. But is it that bad?
Today I did a compression test and found 124, 110, 90, 110, 110, 112, 110, 0,
#3@90 went to 110 after 3 squirts of oil. #8@0 just fluttered the needle a little.
Both times, before and after the switch, the engine has always ran good, no backfires or stutters. Before would top out at 4600 @ 52mph, after 3900 @ 56mph.
Now I'm REALLY wondering if #8 @ 0psi was really the problem before the prop switch or if testing the new prop at 3900 is what caused the 0psi?
