Re: what angle should i setup to plane in water?
"How do I know when it's planing" - <br />When you start off your boat is sitting "down" in the water, the boat is in the water the complete length of the boat and it goes rather slow. As you increase speed the hull trys to lift out and "plane" on the surface. At some stage you'll find the boat appears to suddenly pick up speed and sits much higher on the water. You may even have to throttle down a bit to keep a safe speed. This is planing. Believe me mate, you'll know when you're planing.<br />Ross
