PiratePast40
Thread starter- Joined
- Mar 21, 2009
- 1,734
Volvo AQ130D (older pushrod motor). The motor is out of the boat and in the garage. Everything is put back together and ran a cold compression test by turning it over with the starter. All cylinders came up to 115 to 118 lbs quickly and held pressure for a few minutes before I switched to the next one. The fact that they all came up quickly, were close to each other, and held pressure gives me some piece of mind. I could't find the recommended compression numbers for the motor in the Seloc manual. What should I be getting for cold compression on this engine?
Thanks
Thanks
