Dan Schmidt
- Joined
- May 2, 2008
- 9
I'm mid-way through my floor replacement in my 1992 Bayliner Capri. After removing the floor, foam, and cleaning everything out, I noticed these grooves in the top of the stringers on either side of the fuel tank. I'm fairly certain they were filled with foam, but intuitively they don't seem like a good idea.
The fuel tank cavity drains into the bildge, but it seems as though these grooves are a path for the foam to get wet (and I'm a bit sensitive as you might guess).
Do I need these, or should I seal (epoxy) them shut and flush to top of stringers? Thanks in advance for your help.
