what are you guys using. Poly or epoxy
oops!
Re: what are you guys using. Poly or epoxy
Ayuh,..... Could ya expand on that abit Oops,..??
The wet resins, or the ground dust,..??
wet resins from inhalation.......some people are getting a severe reaction after using it a few times......then when they get around it again.....it gets really bad.
just depends on the person.
bobcarter
Well i ended up just ordering poly. One question though. Where two pieces of decking meet...do you put anything between the pieces to join them together, or do you just glass over the whole thing?
oops!
a reisn filler mixture that we call "peanut butter"
you will find the recipies in the link in my sig......look in the index for oops sooper dooper peanut butter....
also ....i just came up with a new very structural formula.....
http://forums.iboats.com/showthread.php?t=507690&highlight=sooper+dooper
the filler can be spread like putty.....between each deck joint and the hull and deck joint....then glassed over when wet....(or dry if you wish)
